Floats have two adjustments. One is the "level" it adjusts the level of fuel in the bowl when the carb is full, and shuts off the flow. this acts like a toilet tank float and when in continuous operation running the tractor, is just part way open allowing just enough fuel in to support the flow into the jets and idle ports. It is the distance from the float to the carb body. (usually measured with the carb upside down, or with finger pressure and good "feel" with it on the tractor. The second is float drop. most carbs have this adjustment. It stops the float from dangling too far when the fuel stops coming in (out of gas), or the valve is shut off. The purpose is to prevent the float pontoons from touching the bowl (ever). if they touch, they can stick and prevent control, or just wear and eventually get a hole that sinks them. The pontoons must also be adjusted some times to assure they do not scrape on the sides. Jim
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
