Re: farmall super H wont start
Posted by Janicholson on October 19, 2012 at 18:58:58 from (96.24.99.126):
In Reply to: farmall super H wont start posted by garson on October 19, 2012 at 16:43:08:
Assuming the compression is good, put a teaspoon ful of gasoline in each spark plug hole (plugs back in) and staart it. if it continues to run and start Cool. If there is no joy after 10 seconds, there is probably a manifold leak. (some are internal between the Exhaust manifold and intake. Jim
