I like the way John B is thinking, you're not drawing the gas into the cylinders. Cracked/broken warped or obstructed intake manifold, bad gasket on the intake manifold, valves to tight or hanging partially open. Maybe try giving it a hit of starting fluid and see if she responds if not I'd try pulling the plugs and put your thumb over each spark plug hole while cranking it over to feel if you have vacuum, maybe even do a compression test.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
