Hold your hand over the throat of the carburetor and see if there's good suction while a helper makes an attempt to start the engine. Low suction means you have low intake manifold vacuum. Do the compression check as been mentioned and if it looks good you probably have an intake manifold leak somewhere. Quirt a little starting fluid where the intake mates to your engine while a helper makes an attempt to start the engine. If the engine fires you've probably found the leak. Try tightening the bolts or nuts on the intake manifold if that doesn't help you probably need a new gasket. Hal
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
