Posted by jimb2 on October 20, 2012 at 07:00:17 from (174.114.182.155):
In Reply to: 424 hydraulic fill posted by ronnie jenkins on October 19, 2012 at 15:39:34:
Hi Ronnie, the 3 plugs in the bottom would have drained the trans/diff and mid section of drive train. Normally those parts are filled with 90wt transmission gear oil unless the tractor was an industrial model and then the trans/diff is used as a hydraulic reservoir and is filled with hytran hydraulic oil. The trans/diff is filled by a plug by the gear shift lever and holds 5 US gal. There is a trans/diff lever check plug on side of trans by the brake pedals. Park the tractor with front wheels lower than rear. Put a bucket on the foot stand by the brake pedals. The hydraulic reservoir is then drained by loosening the clamps on the rubber joining hose on the suction line beside the gear shift and sliding the joiner forward towards the engine and then rotate the section of suction pipe connected to the hydraulic housing so that it will drain into the bucket. After hydraulic fluid is drained, the suction filter can be cleaned by pulling forward on the drain pipe and the filter will come out of hydraulic reservoir. Becareful not to damage "O" ring, put some hytran fluid on "O" ring before re-installing suction filter. The hydraulic reservoir is filled by plug behind the seat by 3pt top link housing. It holds about 3 US gal of hytran. To get the air out of hydraulic system, before tightening the joiner rubber put hytran in the reservoir and let the air bleed out at the joint on the suction line. After reservoir is full, leave filler plug loose and joint tightened then start engine and work 3pt up and and PS left and right until air purge from system . Refill reservoir until hytran is above the shelf when you look in the filler hole.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too.
... [Read Article]
Latest Ad:
[More Ads]
