Posted by jimb2 on October 20, 2012 at 07:05:34 from (174.114.182.155):
In Reply to: dual clutch adjustments posted by steven in tn on October 19, 2012 at 18:11:16:
Hi, Bernard le mecano says .090 inches for new clutch, see below.
Hi, you can place all the clutch and pressure plate on the shaft and bolt the engine to the rear end. If you remove the PTO clutch, make sure to aling the clutch carefully in the center of the pressure plate, before replacing the bolts on the fingers, for that, remove the flywheel, place it on flat surface, put the transmission clutch, the plate, belleville spring, plate, PTO clutch, then presure plate, belleville spring and cover. Aling all of the parts, put 3, 5/16 long bolts and hand tighten to the flywheel. Secure the 3 bolts on the fingers and jam nuts, then adjust the gap. Make sure to adjust the 3 fingers at the same level. The gap for the 3 bolts is .090 inches. Remove the pressure plate, replace the flywheel on the engine crank and finish the job. Bernard le mecano
Hi, yes you can, if you don't change the PTO clutch. If so, make sure to center the PTO clutch in the pressure plate before fastening the finger bolts. Re-gap the 3 bolts to .090 inches for the PTO plate. Bernard le mecano
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
