Re: farmall super H wont start
Posted by garson on October 20, 2012 at 13:15:56 from (24.57.81.194):
In Reply to: Re: farmall super H wont start posted by Ludwig on October 20, 2012 at 10:21:39:
problem is the carb is leaking out the neck so its overfilling which means the float isnt stuck. nothings been changed recently. the old guy im buying it from said his son drove it about 3 months ago and parked it it the barn and hasnt run since.
