Re: What kind of paint for a new muffler?
Posted by GordoSD on October 20, 2012 at 16:23:11 from (64.33.250.162):
In Reply to: What kind of paint for a new muffler? posted by dstates on October 20, 2012 at 15:21:32:
Yep, most of the mufflers come with REALLY CHEAP PAINT!. I'd use laquer thinner and wipe all the old paint off. Then dry sand with a DA air sander and 360 papre. Then repaint with your favorite silver hi-temp rattle can.A tack coat, then two wet coats.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
