Re: Adding LH to '42 M
Posted by DeltaRed on October 20, 2012 at 18:44:28 from (67.6.219.50):
In Reply to: Adding LH to '42 M posted by IAtractorKid on October 20, 2012 at 18:01:07:
You can do that.I once had a '40 M that I set up that way.Worked pretty good.Only I used a vane pump and mounted it under the belt pulley.The battery stayed in its spot.I like your idea better...
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
