Re: johnson manifold
Posted by high octane on October 21, 2012 at 05:55:21 from (72.53.194.237):
In Reply to: johnson manifold posted by mm585 on October 20, 2012 at 21:29:23:
make one from a stocker. cut that casted box off the intake, increase the throat size by .100 n its a match to the LP intakes. you could have one done in bout 6hrs! was worth 6hp on a 263 combine engine in a "460H". bad thing bout it was, it gets very cold. on a 100 degree day, it will frost over big time. had to really warm the engine up before a run, or she would sputter just a tad from sucking in condensation water. good luck.
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
