Re: Can't get axel seal to quit leaking.arrrrg!
Posted by Bob R on October 19, 2000 at 15:55:57 from (209.198.116.11):
In Reply to: Can't get axel seal to quit leaking.arrrrg! posted by Paul Shuler on October 19, 2000 at 15:41:53:
Sounds like what I am going through on the H .
My guess would be the sealing surface is worn or rough . Can get it built up (weld ) and ground to size . Mine in leaking at the belly pump seal and main drive shaft seal . looks like someone ground down the drive shaft .
Maby this is the type of problem you have...
post what you find
Post A Followup
: Re: Re: Can't get axel seal to quit leaking.arrrrg!
