Re: Super A hitch ?
Posted by CNKS on October 21, 2012 at 08:01:15 from (216.144.104.128):
In Reply to: Re: Super A hitch ? posted by JRSutton on October 20, 2012 at 10:57:46:
Why not swinging? I drove an H pulling trailing implements without hydraulics from 1950-1958 and the swinging part was never locked down. Anyone who says that does not help turning has either not used trailing implements or has very light ones--we never needed to lock it. I also did that on JD 3020's, 4020's etc. There is no question that if it is left in the ground when turning, that it is easier.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
