Re: Off topic propane torch
Posted by Keith-OR on October 21, 2012 at 10:18:31 from (208.65.217.6):
In Reply to: Off topic propane torch posted by CGtractor on October 21, 2012 at 09:06:43:
Propane tip is definitely different. Like matthies said you need the two piece tip, designed for propane. Don't listen to the old wifes tales that propane needs different hoses and or gauges. Tip is all that needs to be changed!!!
I switched to propane for cutting back in the early 70's, a lot cheaper to operate. Does not work worth a darn for welding though.
