Hi Bwholl, I would check the simple things first, the PTO lever engagement mechanism. Check for sticks and other debris that may have fallen down at back of seat and around PTO lever. Next with your favorite penetrating oil lube all the PTO lever mechanism from the lever all the way over to behind you left heel were it pulls a hydraulic control valve on top of the MCV valve. There is a rubber boot over the PTO valve, carefully pry that up and squirt some penetrating oil under the boot while working the PTO lever ON and Off. If that doesn't fix the PTO problem, then a hydraulic pressure gauge with proper fitting is required to check PTO clutch hydraulic pressure.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
