Re: splitting revisited
Posted by sflem849 on October 21, 2012 at 15:46:18 from (166.181.3.177):
In Reply to: splitting revisited posted by pete_5959 on October 21, 2012 at 12:53:26:
pete_5959 said: (quoted from post at 12:53:26 10/21/12) Thank you for the quick response. Will be replacing clutch along with finishing the transmission rebuild. I purchased a splitting stand for front of tractor and was planning on using cherry picker to hold rear section up and slide to rear.
Sounds like an iffy plan to me. That cherry picker isn't meant to do that. Also, they are very tippy with a heavy load. There is NO way it is rated to handle that kind of weight.
I use a jack and cribbing on the rear and roll the front forward. It seems popular with the little tractor guys to move the rear back, but my stands are made to roll the front. That is the way most pro mechanics stands are that I have seen around here.
third party image
This post was edited by sflem849 at 17:34:42 10/21/12.
