Re: IH 574 2250 Won't Lift
Posted by Rich Hauer on October 22, 2012 at 05:23:13 from (143.236.88.43):
In Reply to: IH 574 2250 Won't Lift posted by Rich Hauer on October 21, 2012 at 17:49:57:
Thanks for the suggestions. It works now. I did nothing except lower the lift which finally went down like normal with the power off. Fired it up and all works well. Is it possible air entered the system? It is possible I hooked it backwards. This is the first time I unhooked it (purchased recently) and did not record the line placement.
