Re: Wiring Diagram for 400 farmall 12v alt conversion
Posted by oldtanker on October 22, 2012 at 21:27:27 from (66.228.255.239):
In Reply to: Re: Wiring Diagram for 400 farmall 12v alt conversion posted by Roy J. Mantonya on October 22, 2012 at 15:37:22:
Take the standard wireing diagram, eliminate the wiring for the genny and VR. Build new harness without wiring for charging system. Add in wire/wires needed for the aleternator. Should work just fine. Just make sure everyting is hooked up as it should be.
Basically you should have a hot wire to the ignition switch from the battery terminal on the starter, a wire from the ignition switch to the coil. A hot to the light switch again from the starter terminal. Positive cable from a 12 volt battery to the starter and the - to a good ground on the tractor. One wire alternator goes to the amp guage and from there to the hot terminal on the stater where the batt cable is hooked up. A 3 wire alternator should have another wire to the ingition switch. Lights should be wired the same way as from the factory.
Rick third party image
