Re: Super-A hydraulic Problem
Posted by Jim Becker on October 22, 2012 at 21:31:46 from (173.74.120.222):
In Reply to: Super-A hydraulic Problem posted by Gary730 on October 22, 2012 at 13:44:27:
Does this only happen if you run an arm to the end of the stroke, or does it happen if you stop them both somewhere in the middle?
