Re: Can fast hitch from 400 be added to M
Posted by Wardner on October 22, 2012 at 23:21:49 from (4.154.224.142):
In Reply to: Can fast hitch from 400 be added to M posted by 340Wisc on October 22, 2012 at 16:04:51:
The first M sized tractor that will more or less accept a 400 Fast Hitch is the SMTA. Yes, you could swap in the F-400 top frame cover or just make a plate to accept the rigid end of the rock shaft. I've done both. I wouldn't just drill vertical holes into cover unless I could be sure they were "blind". Believe me. They won't be. The 400 frame cover will also need adjustments to accept the steering post. A 450/560 is an easier switch as you don't need to worry about the rock shaft.
third party image
