Re: No Spark
Posted by old on October 23, 2012 at 16:09:23 from (209.86.226.40):
In Reply to: No Spark posted by MKL on October 23, 2012 at 15:36:05:
First check point gap at all 4 lobes on the distributor shaft and make sure the points open very close to the same on all 4. Next if that checks good spray the inside of the cap with starting fluid and blow dry it if you have a compressor. If you see any lines after doing that on the inside of the cap your cap is cracked where you see those lines. If that is ok try a new rotor I have seen those go bad out of the clear blue but then I also keep old ones on hand so when and if the new one goes bad I have a spare
Today's Featured Article - The Great Escape - by Dave Hollrah. It all began Monday with a little baling of second crop on the lake shore field, and as I drove out past my sister and her hubby's place, this small calling sound could be heard from the general direction of their manure pile. Out of the yard, over the cows and bale piles, through the dozer piles, poplars, and brush, out onto the ditch grade road, past the noisy 6.2 diesel engine pulling my well traveled Suburban along. Well it sure didn't take me long to figure out what it was because I alrea ... [Read Article]
