Re: Super H serial numbers
Posted by Pat in Wis on October 23, 2012 at 19:53:32 from (66.206.49.157):
In Reply to: Re: Super H serial numbers posted by Huskers86 on October 23, 2012 at 18:46:45:
With the tag missing it's hard to get exact. The
spread between the chassis serial number and motor
serial number increased as production went on. The best I can do is crunch some
numbers from known tractors that I have both chassis and motor number
to compare, then I trend it to see where the
unknown numbers would most probably land. I don't
have info on any tractors within 50 numbers of
yours so it's hard to be more precise. I'll get as
close as I can for you. The more data I can
compile the more accurate I can be. that's why
it's helpful for me to get both motor and chassis
numbers from anybody that has them. also any SW4
motor serial and chassis serial info is useful
because they used the same C-164 motor. Pat
