Posted by mkirsch on October 24, 2012 at 11:28:48 from (64.80.110.74):
In Reply to: superh posted by rickdeere on October 24, 2012 at 11:20:45:
With a compression of 55PSI, I'm surprised you can even get it to start. That is VERY LOW. Compression should be 125PSI or higher on a new engine.
If all you did was throw a set of rings in it, I'm not surprised that you got the results that you did.
At the very least, the cylinders need to be checked to make sure they're not worn excessively. If they're okay, you need to hone a cross-hatch pattern into the cylinder walls which will seat the rings and create a good seal.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
