Posted by rustred on October 24, 2012 at 12:00:22 from (72.172.100.113):
In Reply to: Block Cleaning posted by Nate V. IA on October 24, 2012 at 10:20:49:
all depends what your plans are for this tractor. if you want some thing that runs and just as a play thing around the yard that can be running with very little expence. get your self some emery cloth and a flat file and put your elbow grease to it. pull the pistons hone the cyl"s. clean the block deck and if any pits in it use j b weld in them and file flat. as i say its your call , but just saying that a big professional engine job spending thousands of dollars is not nessessary when it will run with a couple hundred dollars worth, and a lot of time spent just in the cleaning up department. i have seen worst that that that i have made run. after all what do you think those soaker engines look like inside after being freed up? the pistons are running up and down in rust scoring the cyl"s more.but this is just a little advice that when you want a stuck engine to run is to take it apart and clean all rust out.
and hey, then you can say that "i made this thing run" and you also have gained experience working on an engine . thats what it is all about and then you gain knowledge for the next round. of course it can use sleeves and pistons, but its totally not nessessary to get the tractor running. good luck.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
