Posted by BigTone on October 24, 2012 at 16:18:59 from (70.192.2.242):
In Reply to: Block Cleaning posted by Nate V. IA on October 24, 2012 at 10:20:49:
Nate, I just did a major overhaul on my M over the summer. I brought the block and head to a machine shop, had it taken apart (removing the crank is tough without the tools or knowledge and I had neither), crank ground and new bearings replaced, cam checked, complete engine kit (sleeves/pistons/rings/bearings), I had the head completly rebuilt, deck resurfaced, and the short block re-assembled. All in all I spent $3,200 on the rebuild (just the engine). Sounds like your going to be doing the brunt of the work yourself so you should be saving much more than I did so my advice would be if your going to do it, do it right (im glad i did). take it to a machine shop, they will check the block/head for you to ensure that its not cracked, and tell you what needs to be done. Then you can decide how far you want them to go before you begin the rebuild. Best of luck, sounds like a cool project, give us updates on how it goes! ~Anthony
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
