Re: Ran good when parked
Posted by John G. Hasler on October 25, 2012 at 07:48:47 from (174.124.22.175):
In Reply to: Re: Ran good when parked posted by MCOHIO on October 25, 2012 at 07:23:10:
> I have heard that ethanol asorbs moisture...
Yes. That"s why gasline deicer contains alcohol. You"re less likely to have problems with water in your fuel if you use gasoline with ethanol added.
> ...as well as having a corrosive effect on metal
> parts not designed to work with ethanol.
No. Ethanol does not corrode metal.
