Posted by old on October 25, 2012 at 08:50:01 from (209.86.226.34):
In Reply to: Ran good when parked posted by DanR on October 25, 2012 at 06:28:02:
Surging is caused by it running lean so try these things. #1 pull the carb drain plug and let it flow for a couple minutes catch the gas so as to look for water/dirt/rust. If you do not have a good flow there work your way back till you find where clogged and fix that. If you have a good flow at the drain then #2 pull the main jet and needle out of the carb and again let gas flow there. If little or no flow use a small wire to poke into the jet it self to clean it out and then try to run it
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
