Posted by d282 on October 25, 2012 at 10:50:20 from (209.152.94.237):
In Reply to: d282 parts posted by gaston ruiz on October 25, 2012 at 00:18:10:
You will also need the combine oil pan and oil pump. If you are using a tractor block you will need to drill out the back plate mounting holes because if you screw bolts in they will tend to break. The hydraulic bracket is different as well. I converted my 403 last year and am happy. Make sure you have the pump turned up to run the correct RPMS. You can use the gas wiring harness for for everything on the diesel. Good Luck
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
