Re: Re: Re: Cranked her up All four clyinders even H farmall
Posted by The Red on October 20, 2000 at 07:49:30 from (206.246.187.2):
In Reply to: Re: Re: Cranked her up All four clyinders even H farmall posted by Bob R on October 20, 2000 at 07:24:39:
Yes you will have to drop the belly pump to replace the seal. Get help to lower it. The pump/reservoir assembly weighs around 100 pounds. The face of the belly pump is the actual pump assembly itself. After you remove about 10 perimeter bolts, the entire pump assembly will come out. Stick a large screwdriver or a flat piece of metal up into the intake so the coupler won't turn. You turn the coupler counter clockwise to unscrew it. Then you can replace the seal. Don't forget to order a new reservoir gasket also. When you get ready to stick the pump back into the reservoir, make sure you get that eye hole on the cam and piston valve lever, which is on the pump, connected to the control shaft lever which is on the inside of the control rod lever assembly on the reservoir.
Home
| Forums
Today's Featured Article -
Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
