Re: six volt starter/ farmall c tractor.
Posted by old on October 25, 2012 at 15:30:00 from (209.86.226.57):
In Reply to: six volt starter/ farmall c tractor. posted by James w. Albright on October 25, 2012 at 14:35:04:
Clean tight and bright so you have to make sure ALL connections are good plus you have to have the correct size battery cables. A battery cable can also go bad and you can not see when they do and 12 volts can make things work with poor connections or bad cables
