Re: six volt starter/ farmall c tractor.
Posted by oldiron29 on October 25, 2012 at 15:40:00 from (74.88.11.200):
In Reply to: six volt starter/ farmall c tractor. posted by James w. Albright on October 25, 2012 at 14:35:04:
James, Farmall C and super C Had bad grounding point. Remove the gound cable from the sheetmetal on the steering pedistal and bolt it to the casting with the bolt under the battery box. Good ground and your starter will work fine. oldiron29
