Re: Re: Re: Super A front end
Posted by Dave on October 20, 2000 at 08:58:03 from (128.113.83.150):
In Reply to: Re: Re: Super A front end posted by Mike Settle on October 20, 2000 at 06:09:45:
You can adjust the rear wheel tread width to match the front by putting the wheels and rims on differently. Obviously widening out the front end to accomodate widely spaced crops does you no good if the rear end isn't set the same way. I always wondered why the front end alone was adjustable until I learned about putting the rear wheels on inside-out to widen them out to. Then it all (finally) made sense.
Post A Followup
: Re: Re: Re: Re: Super A front end
