Re: Super A sloppy steering
Posted by gene bender on October 25, 2012 at 18:50:25 from (207.177.56.85):
In Reply to: Super A sloppy steering posted by Phillip Low on October 25, 2012 at 14:21:22:
Start at the tie rods and work toward the steering sector. Mite need to take it apart and replace parts. All seals, bushings and gaskets arent hard to find. There is also a bearing thats bad. Ive done several when done they work just fine. I like to jack up each end of the axle to grease the spindles to get grease at the bottom where the wt rides. Even have removed the spindles to make sure grease fitting is good and get lube to the bottom. There is also a key on the gear that mite need some attention.
