Re: M rearend noise
Posted by Janicholson on October 25, 2012 at 19:49:59 from (96.24.99.126):
In Reply to: M rearend noise posted by Jason in MO. on October 25, 2012 at 19:36:46:
The wear pattern of the differential pinion to ring gear was probably worn in over many years of the eventual failure of the intermediate bearing you replaced. A new bearing will likely change the angle of the pinion to some degree or another, possibly making much more noise. (assumes the other bearings are in good shape) Jim
