Posted by Janicholson on October 25, 2012 at 20:57:54 from (96.24.99.126):
In Reply to: Re: M rearend noise posted by Jason in MO. on October 25, 2012 at 20:20:16:
It is beginning to seem to me to be a bearing or drive coupling issue. The new bearing needs to be held in place (my opinion) is the shaft is worn where the bearing is now located, the new bearing might be allowing the shafts to be improperly aligned and noisy. If the noise happens while the tractor is stopped in neutral, the issue is not the pinion and ring, these are not moving. If it is present when the tractor is in fifth the bearing is not used, therefore it should be silent. If the noise is still there in fifth, the coupling may be incorrectly put together. Jim
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
