Posted by Centex Farmall on October 26, 2012 at 05:14:25 from (32.176.40.211):
In Reply to: M rearend noise posted by Jason in MO. on October 25, 2012 at 19:36:46:
Just to clarify, do you mean you replaced all bearings on all three shafts in the transmission?
I'm surprised that IH is selling the double ball bearing. Last one I bought from them was still the roller type.
We did put on of the double ball bearings (bought from an aftermarket source) into an M to see how it would hold up and so far so good.
The deal with the bolt: The original design was two separate parts and the bolt and washer kept the rollers and cage from walking into the end of the input shaft. With the double ball bearing all the parts stay put and the whole assembly doesn't have anywhere to go to and so the bolt is not needed and IIRC there is no longer room for it.
As Jim said, if the gears have created a pattern via dirty oil and worn bearings and then you put in new tight bearings then the pattern is disturbed and it makes some noise.
I had a similar thing happen on a Super M, but the noise source was primarily the ring and pinion. I had replaced every bearing and had made the best attempt at matching the existing pattern on the ring and pinion. I may tear back into it sometime and re-shim the thing.
In neutral though it hardly makes any noise. Since yours is making noise even in neutral that's why I ask if every bearing in the trans has been replaced.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
