Posted by mkirsch on October 26, 2012 at 05:46:03 from (64.80.110.75):
In Reply to: plow with 706 posted by morris roessler on October 25, 2012 at 15:29:24:
710 is a semi-mount plow.
AFAIK, you lift it out of the ground by first lifting the 3pt, then switching to the hydraulic remote lever to lift the tail wheel. It's the part I could never get the hang of.
If your tail wheel is lifting slow, check for a flow restrictor device in the hydraulic hose for the tail wheel. It will look like a short piece of pipe in the line. It also can be built into the elbow that goes into the cylinder. Flow is not adjustable on a 706.
Another possibility is that the hydraulic hose has collapsed internally.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
