Re: H just stopped
Posted by old on October 26, 2012 at 09:44:08 from (209.86.226.58):
In Reply to: H just stopped posted by alderman on October 26, 2012 at 01:24:00:
Well #1 check battery to make sure it is not dead. #2 check battery cable connections. #3 check battery cable connections where they go to ground and where they go to the starter button. #4 use a jumper cable from the battery ignition side right to the starter. BE 1000% sure it is out of gear and see if it will spin over by doing that. If it does then the starter button is bad. If it does not the start is locked up to the flywheel or it is bad or a cable connection is bad. No matter what you should get a few sparks when you use the jumper cable
