What tractor are you messing with is it also a Cub?? You can also use the TDC way as in get #1 piston up at TDC then line up the rotor on the mag so when installed it sits close to where it would fire and that gets you in the ball park so once running you can fine tune it. I use that way when people make the mistake of pulling the distributor out of things and then forget it has to go back in just so or it will not work. You do not know how many people will pull a distributor then move the engine and then find out timing the distributor is a key factor to a running engine
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
