Re: leak at final drive
Posted by Jim Becker on October 20, 2000 at 10:50:15 from (207.43.195.201):
In Reply to: leak at final drive posted by Gorki on October 20, 2000 at 09:29:03:
You could have a leak where the pan bolts to the final drive housing or it could be axle seals. If at the pan, it is assembled with a cork gasket. The manual says the fill plug is also the oil level, but that leaves oil constantly against the pan gasket. You can leave the level lower, so it isn't against the gasket but the bull gear is still running in oil. The oil will circulate but the leakage may stop.
Post A Followup
: Re: Re: leak at final drive
