Re: Farmall Super C surging
Posted by Janicholson on October 26, 2012 at 17:23:07 from (96.24.99.126):
In Reply to: Farmall Super C surging posted by Dean Olson on October 26, 2012 at 15:59:36:
The spring is a band aid for worn linkage rod and holes. I would redo the carb and rod joints to remove all slack. The spring system can apply enough tension to the joints that they stick just a little. That causes surging.
The carbs are not adjustable for high speed/power. richness adjustment can be adjusted with larger main jet, or float adjustment (1/16 higher level in bowl, closer to the carb base)
Jim
Today's Featured Article - The Great Escape - by Dave Hollrah. It all began Monday with a little baling of second crop on the lake shore field, and as I drove out past my sister and her hubby's place, this small calling sound could be heard from the general direction of their manure pile. Out of the yard, over the cows and bale piles, through the dozer piles, poplars, and brush, out onto the ditch grade road, past the noisy 6.2 diesel engine pulling my well traveled Suburban along. Well it sure didn't take me long to figure out what it was because I alrea ... [Read Article]
