Re: IH B with cotton picker
Posted by IBleedIHRed on October 26, 2012 at 19:26:03 from (108.131.90.251):
In Reply to: Re: IH B with cotton picker posted by Hugh McKinney on October 26, 2012 at 06:27:27:
Thanks for all the input, found the pictures at the WHS.
The most common low-drum picker was mounted on a Farmall H or SH, some SC were tried and worked in West Texas on flat ground, did not work well climbing the hills of Mississippi.
High-drum was needed in the Delta, taller plant height, skip-row pattern.
