Re: Farmall H engine surges
Posted by The Red on October 27, 2012 at 07:11:52 from (69.246.205.0):
In Reply to: Farmall H engine surges posted by 53H on October 27, 2012 at 03:46:43:
Couple of things I have encountered wrenching with Hs for 20 some years. In the governor, check the thruster bearing and make sure it is sliding back and forth horizontally but not wiggling. Had that happen on a 1951H. But it surged whether loaded or not loaded.
Other thought is look at the end of the throttle rod on the top of the engine and inspect the control rod swivel assembly on the end. It might be loose or even have a spring missing. Had another H that had that problem.
