Re: Setting points on F-20 with F4 magneto
Posted by El Toro on October 27, 2012 at 07:56:03 from (108.3.143.30):
In Reply to: Setting points on F-20 with F4 magneto posted by Duanes on October 26, 2012 at 13:00:38:
Just bump the engine over until the rubbing block on the points is on the high point on one of the lobes. Then adjust your points. Coat the lobes with some lube so the rubbing block doesn't wear so fast. Hal
