Re: 400 gas 12v alternator with tach drive
Posted by Janicholson on October 27, 2012 at 08:00:48 from (96.24.99.126):
In Reply to: 400 gas 12v alternator with tach drive posted by jim_uny on October 27, 2012 at 07:32:20:
To the best of my knowledge there are no tach drive alternators (at least there are sure none used on X00 series Farmalls). the tach is driven from the distributor drive housing (very similar to the cable drive on a speedometer on a car. Electronic tachometers using a sample of coil primary pulses to operate are commonly available in many sizes. I would choose that option unless you are making a restoration that needs to be stock. (which you are evidently not doing) Jim
