Re: farmall b starter
Posted by old on October 27, 2012 at 13:14:08 from (209.86.226.34):
In Reply to: farmall b starter posted by cuttman on October 27, 2012 at 11:26:30:
Can be caused by a few things. Weak battery will do that as will the bendex area of the starter being full of oil/grease/dirt and of course a bad bendex will cause that. As will bad teeth on the ring gear. To test if it is bad teeth just turn the engine over by hand say a 1/4 turn and try it. If it spins like it should then could be bad teeth since and engine stops pretty much the same place when shut off
