Re: H nine speed
Posted by Zachary Hoyt on October 27, 2012 at 13:22:03 from (184.12.70.70):
In Reply to: H nine speed posted by J. Rasmussen on October 27, 2012 at 13:04:37:
You can put it in if you put in all of the transmission gears and shafts from the H. The SH uses different gears that are thicker and the 2 3 and 4 gear ratios are different. The upper shaft that the sliding gears ride on is also different to make room for a bigger pilot bearing. I put Super H gears and shafts in my 49 H and I like the SH gear ratios and superior strength.
Zach
