Re: 460 farmall
Posted by Owen Aaland on October 27, 2012 at 13:42:57 from (216.47.32.147):
In Reply to: 460 farmall posted by David G on October 27, 2012 at 05:33:21:
The 460 was the first series to use a transmission mounted hydraulic pump instead of an engine mounted pump. There is no common area where the hydraulic oil can enter the crankcase.
