Float could be sticking. The way I check that is turn the crab up side down then right side up and listen for the float to move. You should hear a diffident rattle sound when you do that if not then yep float is hanging up. Also you have to be sure the float needle seat is good and tight or it too can leak and cause the same problem
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
