Re: M Started! Carb still leaks?!?!?
Posted by BigTone on October 27, 2012 at 15:02:36 from (70.192.11.71):
In Reply to: M Started! Carb still leaks?!?!? posted by BigTone on October 27, 2012 at 13:24:41:
Heres another question: I replaced the exaust manifold, when I was putting the carb on I noticed the holes that are drilled in the bottem of the manifold were offset. When I bolted the carb on it looked like the outlet of the carb and the inlet of the manifold were not going to line up 100%. Could this not lining up be doing something to the venture (sp) which is allowing gas buy it for some reason? IDK, just a shot in the dark. Bought the manifold months ago on ebay and im sure its to late to return.
