Re: M Started! Carb still leaks?!?!?
Posted by Don Hopf on October 27, 2012 at 16:09:19 from (216.16.80.32):
In Reply to: M Started! Carb still leaks?!?!? posted by BigTone on October 27, 2012 at 13:24:41:
The brass float lever pivot support could be twisted causing the float to hang up on the bowl. Had this happen on a 400 carb.
Don
